DC Motor Controller
Re: DC Motor Controller
Good info there tumbleweed, and welcome to the forum
- Joined: Mon Aug 30, 2010 8:05 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I made a quick design for a circuit board now that the circuit itself seems to be in place
The only detail im somewhat worried about is the connection from pin 4 of the 555 to VCC, I couldnt get around easily so what I did is I managed to connect it to the cathode of the third diode (parallel to the motor) which goes to VCC as well. Please let me know if that is a huge mistake I know the design isnt the best but it was a bit of a rushed job and for know I just trying not to blow it up.
If you see any other mistakes please let me know, Ive attached the screencap
- pwm motor screencap.JPG (58.3 KiB) Viewed 11100 times
Could you post the diptrace design file? you may have to put it in a zip file first to post to the forum though.
