Swordfish board for Arduino - work in progress
Re: Swordfish board for Arduino - work in progress
Post by bitfogav » Wed Jun 04, 2014 12:39 am
brad wrote:74595's are a great chip, I used them on my DigiPixel board and I am in the process of designing a board for work with a bunch of LED's on it.
Yes indeed, the 74595 is a very handy chip if you want more outputs. I used them in one of my last projects also to drive led's :)
Matrix Shield
Garth
Post by Garth » Wed Jun 04, 2014 5:18 am
brad wrote:
Use 'em for even hundreds of output bits:
http://wilsonminesco.com/6502primer/pot ... #22_SR_OUT
Wow, you have loads of great tips on that page!
Thanks. I have quite a bit more to add when time allows.
Post by bitfogav » Thu Jun 12, 2014 12:41 am
I have already designed another version of the board, this time it supports 3.3v and 5v microchips (18F4550.18F4553,18F46J50,18F47J50) :)
Post by brad » Sat Jun 14, 2014 10:34 pm
Well done bitfogav :)
Is there some sort of jumper that you use to select between 3.3v and 5v?
Post by bitfogav » Sat Jun 14, 2014 11:02 pm
brad wrote:Well done bitfogav :)
Yes indeed, it's pretty much a cheap way by using some solder surface pads :) this only changes the power supply to the main chip, you still have 5v and 3.3v on the headers.
Made my own solder pads in Diptrace:
Post by brad » Tue Jun 17, 2014 6:33 am
That reminds me of the Amiga 500 motherboards. They had similar solder pads that you would short together depending on (I think) what specific chips you had installed.
Post by bitfogav » Sun Jul 06, 2014 5:49 pm
After a few versions of the board I think the board is almost finished (depending on testing).. Over the weekend I have built up the 4 versions of the board (18F4550.18F4553,18F46J50,18F47J50) Here is a sneak look at the boards :)
The boards just going into the reflow oven
All boards complete
Post by brad » Tue Jul 08, 2014 11:28 am
The red boards are definitely my favourite. Nice choice - they have come up just perfectly bitfogav.
Now it looks as though you've got yourself a home made reflow oven, how is that controlled? is there any problem with the sensing element coming desoldered in there?
Post by bitfogav » Wed Jul 09, 2014 3:19 am
brad wrote:The red boards are definitely my favourite. Nice choice - they have come up just perfectly bitfogav.
The red boards do look great :) I do have a reflow oven at home, I brought it nearly 2 years ago and it's been well worth it!.. I enjoy watching the solder paste reflow and all the components self a line.. No problems with the sensing element because it's just a Thermocouple type temperature sensor which I just attach to a piece of pcb board..
The reflow oven was one of the cheapest I could find and the controller is one that you can interface with using a PC (RS232), it's really great for adjusting the correct oven temperatures, to get the correct reflow.. If you want to check out the reflow oven and controller then the links are below.
Beta-Layout Reflow oven
Beta-Layout Reflow oven controller
Also I did find out that David also uses the same reflow controller as myself (for the Firewing boards), and he has put together a fantastic graphical user interface (GUI). check it out here.
Post by brad » Thu Jul 10, 2014 1:33 pm
I love it that RS232 is still in use today, it's certainly easier (in my opinion) to interface to microcontroller devices compared to USB.
I bought one a few years ago swell although the glass panel is so small that you can't really see anything - I wanted to see the solder flowing and aligning all the components!
Post by bitfogav » Tue Oct 14, 2014 3:51 am
I just saw it was 3 months since I posted on this topic last, well time flies!!. I have been on and off this project and others since and I have just received some really nice black boards :)
Post by brad » Tue Oct 14, 2014 6:23 am
Looking very sharp there bitfogav!
Speaking of black boards, here's an older style that I remember from school :wink:
