I recently have been using a DS18B20 temp sensor for measuring a beer cooler temp and making adjustments. I inadvertently disconnected the power wire to the sensor (may have been the sensor wire?) but in any event the sensor now only reads 185, not 34degreesFetc.
I need to add some code to the pic but need to replace the sensor first.
CAUTION using a DS18B20
Re: CAUTION using a DS18B20
Oops!
did you see any magic smoke?!..
Swordfish has its own DS18B20 module.. Check out the Samples folder "OneWire"
Yep, once that smoke get's out there's no going back!
- newbie
- Joined: Fri May 09, 2014 2:43 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I'd say it's okay.bitfogav wrote:Oops!did you see any magic smoke?!..
The sensor itself does not work but after connecting a new sensor everything is a go.
