LED Matrix Font Creator
- waywardson07
- decided to stick around...
- Joined: Wed Nov 24, 2010 5:01 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi everyone, I created a program to assist in the designing of new fonts for LED Matrices and thought that I would share it here for anyone that is interested in using it.
Here is a screenshot:
I have described how to use the program here on my blog if anyone has any interest in that...
http://gabrieldsblog.wordpress.com/2014 ... t-creator/
take care all!!
UPDATE: I created a Mac version of the program. Here is a screenshot:
I updated my blog with the Mac version as well.
take care all!!
Re: LED Matrix Font Creator
A big thanks for sharing! This is exactly the sort of program that I like making to make life just that little bit easier when working with LED matrix displays.
What did you code this in?
- waywardson07
Thanks brad!
It's coded in c#.
I'll most likely make a MAC port as well, because I use my MacBook more often than I use my windows machine. I'll update the post when I do.
It's coded in c#.
Be sure to let me know of a Mac version since that's also what I use mostly
What compiler / IDE did you use to make it?
- waywardson07
Brad... I used Visual Studio 2012 for the windows version. It could have been written in basic or c++ as well, but i chose c#...
Also, I updated the main post with the new Mac version I made.
Thanks for the Mac version, just downloaded and tested it and it too works like a charm.
Is there any chance you could share the Xcode project so I can take a look at your source code?
- waywardson07
No Problem... Ill attach the project to this comment.
However, be warned.. I woke up and wrote the project in about an hour.. so its not optimized. lol
Sorry for the late reply, I have just downloaded it. I'll check it out and post if I have any questions. Thanks again!
Users browsing this forum: No registered users and 11 guests
