Thats a strange result? the code works perfect on my KS0108 GLCD. Ive made two more Hex files you could try, I have increased the delay warm up time of the GLCD on both Hex files, the only difference is the CS lines, ive changed one to inverted and one to non inverted.. thats the only thing I can see that might make it work correctly, the other options are that your GLCD maybe not a true KS0108? or your circuit I guess.
I have found out that it is a good idea to have a Decoupling capacitor on the GLCD circuit.
Has for my GLCD the extreme left upper corner is X=0,Y=0 - right lower corner X=127, Y=63 same as yours.
The two Hex files:
Microcontroller based Graphical lcd game
Re: Microcontroller based Graphical lcd game
bitfogav wrote:Thats a strange result? the code works perfect on my KS0108 GLCD. Ive made two more Hex files you could try, I have increased the delay warm up time of the GLCD on both Hex files, the only difference is the CS lines, ive changed one to inverted and one to non inverted.. thats the only thing I can see that might make it work correctly, the other options are that your GLCD maybe not a true KS0108? or your circuit I guess.
The two Hex files:
THANK YOU very much Bitfogav, the non inverted hex works flawlessly for me. appreciate your effort , one more thing though, could you make a special non-invertedcs_delay hex file for me that had my name in the welcome message, like " GLCD Game by Captalex". thanks man.
There you go
- GLCD Pong NonInverted_UpdatedCaptalex.rar
- (3.64 KiB) Downloaded 754 times
bitfogav wrote:There you go
thank you bitfogav!!,
- odessa
- Location: London [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Have you got any futher with this Gav ?
(\_/)
Honest answer Jay, No not yetodessa wrote:Have you got any futher with this Gav ?
