Brads Electronic Projects Forum • 24 Channel LED driver with 12-bit PWM
Posted: Sat Jul 03, 2010 7:55 pm
This chip has a few more channels than one that Chuck suggested a few months ago, but basically does the same thing.
The TLC5947 chip is a 12-bit PWM constant current LED driver with 24 Channels. Why is this cool?
Well I am glad you asked, it is the perfect chip to drive an RGB LED matrix display!
I ordered some samples from the texas instruments website today, so I will let you know of my findings. I am planning on using one of these in the redesigned LEDBOY system.
imagine that, 12 bit's per channel! So that means that each RGB Pixel has 12-bits for red, 12-bits for blue and 12-bits for green. That is a total of 36-bits.
36 bit colour! That means each pixel can be any one of 171,798,691,840 colour combinations!
The chip has serial input and tri-state parallel outputs. very nifty indeed :)
Re: 24 Channel LED driver with 12-bit PWM
Posted: Mon Sep 27, 2010 12:27 pm
by Digg
Has anyone used this chip? If so what package and how did you mount i?. Ive never had a chip with a thermal pad before. Any information would be a great help.
Posted: Mon Sep 27, 2010 6:49 pm
by Mitchy
12bit - doesn't that mean that its 2^12 = 4096 steps?
3 Colors on a LED, that makes 4096 x 4096 x 4096 = 68,719,476,736 combinations. Or am I missing something?
Posted: Mon Sep 27, 2010 8:54 pm
oops my mistake!
