by Chuckt » Sat Oct 15, 2016 2:33 pm
Aven 17010 Adjustable Circuit Board Holder
Ideal for clamping PCB, for soldering/desoldering or rework
Retractable to accommodate various board sizes up to 198mm wide and up to 4mm thick
Clamps allow PCB to rotate 360 degrees
Rigid metal structure
Rubber feet of the base ensure stability
It is cheaper than PanaVise which might help newcomers get into electronics if they can't afford it.
https://www.amazon.com/Aven-17010-Adjus ... 26M8RABA0C
by brad » Tue Oct 18, 2016 8:26 pm
We have these when teaching soldering at work however I still default to 'just putting the board on the bench'
