Professional 37-in-1 Sensor Module Kit for ARDUINO compatible
Complete Update and common models for arduino UNO NANO R3 Mega 2560 starter kit
compatible for raspberry pi RPi 3 2 Model B A A+ B+ sensor kits
Standard interface can be controlled directly by microcontroller ( 8051, AVR, PIC, DSP, ARM, ARM, MSP430, TTL logic)
Detailed tutorials including project introduction and source code CAN BE PROVIDED FOR FREE, contact us BY Email to get documents.
https://www.amazon.com/Arduino-Kuman-Pr ... rd+EditionUpdate version than 37 sensors modules: add 100 X Resistors (10 each / 10, 100, 200, 330, 1K, 2K, 5K, 10K, 100K, 1m ohm) and one tutorilas CD at free
Packing list:
1. Analogy-Hall sensor Module×1
2. Magic-ring Module×1
3. Rotate-encode Module×1
4. Light break sensor Module×1
5. Finger-Pulse sensor Module×1
6. Magnetic spring Module×1
7. Obstacle avoidance sensor Module×1
8. Tracking sensor Module×1
9. Microphone sensor Module×1
10. Laser-transmit Module×1
11. Relay Module×1
12. 18b20 temperature sensor Module×1
13. Digital-Temperature sensor Module×1
14. Linear-Hall Sensor Module×1
15. Flame sensor Module×1
16. High-sensitive voice sensor Module×1
17. humiture sensor Module×1
18. Joystick PS2 Module×1
19. Infrared-receive sensor Module×1
20. Passive Buzzer Module×1
21. common-cathode RED&GREEN LED Module×1
22. Knock sensor module×1
23. Shock-switch sensor Module×1
24. Photo resistor sensor Module×1
25. Push button Module×1
26. tilt-switch Module×1
27. RGB LED Module×1
28. infrared-transmit Module×1
29. RGB LED Module (SMD)×1
30. hydrargyrum-switch sensor Module×1
31. two-color commoncathode LED Module×1
32. Active buzzer Module×1
33. Analog-temperature sensor Module×1
34. Colorful Auto-flash Module×1
35. Magnet-ring sensor Module×1
36. Hall sensor Module×1
37. touch sensor Module×1
I'm not sure how they can do all of this for $32.99 but...
Amazon lists other kits and other kits will come up on the bottom of the page that you can explore...
