[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 580: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 636: sizeof(): Parameter must be an array or an object that implements Countable Brads Electronic Projects Forum • Repost, great 10 x 12 Matrix video.
I did post this before the site crashed, here it is again wouldn't mind having a go at somthing like this.
Just need to find myself a block of flats to play with
There are quite a few different versions on the same building
Re: Repost, great 10 x 12 Matrix video.
Posted: Sat Jan 15, 2011 8:35 pm
Thanks for the repost!
Fantastic video clips - I'd love to be involved in such a large scale project like this
Posted: Sat Jan 15, 2011 10:49 pm
by Mitchy
A few guys at Digital DIY are putting together an excellent DMX lighting module for the Swordfish compiler.. It allows control of up to 512 channels (with any DMX compatible devices).
Looks like the above project makes use of RGB lighting, which would be 330 channels on a 10x11 grid. With the hardware + firmware out of the way, its just the block of flats you need!!
Posted: Sun Jan 16, 2011 5:53 am
If only you could get a block of flats for cheap on ebay!
