Flux
- 1kiko1
- Joined: Wed Jun 29, 2011 11:16 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Flux
Hey brad when you are soldering the 8x8 do you have to use flux
Re: Flux
I don't bother to use flux unless I am soldering surface mount components.
There is flux already in the solder, but when it comes to fine soldering (surface mount) you want all the help you can get so I highly recommend flux. I just use a flux pen which costs around $5
- sdudley
Re: Flux
I always flux my capacitors!
Re: Flux
Just be careful not to go faster than 88Mph when transporting your fluxed capacitors
- sdudley
Re: Flux
I already did that and wound up in the future. Think about it... by the time you read this, it will be the future! So technically I am writing to you in the future.brad wrote:Just be careful not to go faster than 88Mph when transporting your fluxed capacitors
