Hello! I would like to have explanation on this :
bcf PORTA, 1 ; turn on the RED LED and
bsf PORTA, 0 ; turn off the GREEN LED.
what is bcf and bsf and PORTA ?
just a little idea, at the beginning i could write reaction game , but how do i write that on a 7 segment display ?
thank yoU!
marC:)
explanation.. please
nodoubtman
- Joined: Wed Jan 25, 2012 2:54 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: explanation.. please
Check out this tutorial:
http://www.bradsprojects.com/electronic ... rial2.html
It has the info on bsf and bcf.
as for writing text on the seven segment display, you are severely limited - you would want to use an lcd display most probably.
Be sure to check out the rest of my Assembly tutorials which will explain alot of the most common instructions.
