Hi Brad,,
Great site by the way... Just wondering on this 8x85 POV system, how do you save your picture (image) to the eeprom after making it using the HxD?? Do you save it to the microchips eeprom or the 27C512 chip that you use in your project??
how do you ?
Thanks very muchHi Brad,,
To save your picture (hex file) to the eeprom you need an eeprom programmer. you can pick these up quite cheap on ebay and they either plug into your USB port or the parallel port. just do an ebay search for eeprom programmer.
You need to program both. The eeprom holds the graphics whereas the pic holds that info to make the circuit work. You can't use the pickit 2 to program the eeprom unfortunately unless you modified the circuit to use a microchip serial eeprom.bitfogav wrote:Thanks Brad.. so wouldnt a Pickit2 work to programme the epprom?, also I take it you have to programme the 27c512 chip?? and not the 16F628?
Having said that, I am working on a new and improved 8x85 circuit that uses only one chip instead of seven and it does and even better job than the previous one!
yeah sorry i should have made my last message more clear, but i know you had to programme the 16f628 with the program code, i just ment whether you had to program the eeprom on the 16f628.. !! but thanks Brad i understand how your system works better now..
looking forward to seeing your new version of the 8x85 POV
