robertrndya
- decided to stick around...
Post
by robertrndya » Sat Jun 18, 2011 9:17 pm
here it is.
OK
this code doesn't work. (Just so you don't get frustrated trying to make it work)
- code.rar
- (316 Bytes) Downloaded 1319 times
robertrndya on Sat Jun 25, 2011 3:09 pm, edited 1 time in total.
Post
by bitfogav » Sat Jun 18, 2011 11:02 pm
All your PORTS are set as Outputs?. There dont seem to be a Input for the sensor?.
DDRA=0xFF;
DDRB=0xFF;
DDRC=0xFF;
DDRD=0xFF;
Correct me if im wrong but Brads POV design had a sensor pick up, So when the sensor goes pass a nail the program then draws the data on the LEDs. you just have two For Loops that constantly draws the data on the LEDs.
Post
by brad » Sun Jun 19, 2011 8:31 pm
Unfortunately I am struggling to follow your C code.
Have you had a look at bitfogavs suggestion? Have you tried going back to basics and instead of trying to make a picture appear - have you tried making sure that you have the correct data at the output? Have you checked that the eeprom is getting the correct info onto that address bus (I.E. it is not accessing a part of the eeprom that you have not programmed?)
robertrndya
Post
by robertrndya » Mon Jun 20, 2011 3:44 pm
Post
by brad » Mon Jun 20, 2011 8:25 pm
Have you tried displaying each frame more than just twice? maybe at least ten or twenty times each. Sometimes it's very handy to go to the extreme (when all else fails)
Something that could come in VERY handy is a logic analyser, it will show you exactly whats going with your data bus / address bus and is a great tool for fault finding this sort of thing.
A good one is this:
http://www.saleae.com/logic/
robertrndya
Post
by robertrndya » Wed Jun 22, 2011 3:18 pm
Alright, it started working. My friend was helping me with this problem, and he tried different things and at the end all he did is he copied the initializing statements and pasted them before the WHILE loop as well, i.e. the address variables (a & b), latch selecting variable (j), and the control ports (Port C & Port D). Now we have no idea how that makes a difference but it works that way. He just happened to try that out and to our surprise it worked.
Post
by bitfogav » Thu Jun 23, 2011 2:41 am
I see what you mean now, You wasn't initializing your variables before the main "While" loop.
That would probably affect the optimizations of the AVR IDE.
robertrndya
Post
by robertrndya » Thu Jun 23, 2011 2:54 pm
Yes but I was initializing them within the while loop. I was initializing the variables every time it starts a new frame.
Post
by brad » Thu Jun 23, 2011 10:03 pm
robertrndya wrote:Alright, it started working. My friend was helping me with this problem, and he tried different things and at the end all he did is he copied the initializing statements and pasted them before the WHILE loop as well, i.e. the address variables (a & b), latch selecting variable (j), and the control ports (Port C & Port D). Now we have no idea how that makes a difference but it works that way. He just happened to try that out and to our surprise it worked.
Unfortunately I don't think I would have picked that up unless it was a language I used myself
robertrndya
Post
by robertrndya » Sat Jun 25, 2011 3:05 pm
hehehe.....it didn't make much sense to us either. LOL
robertrndya
Post
by robertrndya » Thu Jul 14, 2011 3:35 pm
Hi Guys,
Its been a long time. The POV Display is working fine now. But I have to still spend sometime getting the right data from the software to put in the EEPROM.
Anyways, whats your latest project guys?
Post
by brad » Fri Jul 15, 2011 9:59 pm
My latest project is renovating the new house we have just moved into!
When my new Super Pixel Bros Boards arrive I will test them out and document it though, until then I am painting, plastering, putting in new lights and all sorts of things like that
Post
by sdudley » Fri Jul 15, 2011 10:31 pm
brad wrote:My latest project is renovating the new house we have just moved into!... I am painting, plastering, putting in new lights and all sorts of things like that
Ah, I see... You're neglecting your duties.
Listen man, you need to get a grip on what's really important in life - ok!
robertrndya
Post
by robertrndya » Sat Jul 16, 2011 4:26 pm
All the best with that brad...
Post
by brad » Sat Jul 16, 2011 10:49 pm
Thanks everyone! (except for Stacy...)
1266:
